Weather Satellite Question
I have not dabbled in this area enough to understand much other than setting up software available for decoding APT. The only question is reading elevation and azimuth to determine when a satellite will be directly or nearly directly overhead. I can't do decodes from weather satellites just barely above the horizon. Like I said, I really need them to be overhead even if it takes a week.
In this image I need to know if elevation column can tell me the highest point in the sky. Are higher numbers better?
jwt873
Woodlands, Manitoba
I
Yes.. The elevation is in degrees ranging between 0 and 90. zero degrees is on the horizon and 90 degrees is straight overhead.
majoco
Stirrer
New Zealand
I use WXTrack from David Taylor, Edinburgh - works a treat for me although you do have to keep the Keplerian data up to date but that's fairly automatic
