Webb County Sheriff
chinnesse
Texas
Any body know about Webb county sheriff dept. on SDR Radio just experimenting . Any info greatly appreciated.
BaLa
4GRC+83; Temple, TX 76502
Did you try the VHF Freqs in the DB?
There are some TGs for Webb SO on this system.
If they're using this instead of the SO Freqs, it should be noted under Webb SO in the DB.
Also the VHF Freqs will be fairly easy to monitor the GATRRS will require some software like Unitrunker or ? Not sure if there's anything else other than UT.
chinnesse
Texas
Yes but no results did some frequency search and found some i think its them but totally different frequency . Thank for your response
BaLa
What Freqs? What makes you think its them?
I suspect they are on
'Greater Austin/Travis Regional Radio System (GATRRS) Trunking System'
But I'm not there, so no way for me to know.
This would be another one to check
154.95000000
155.37000000
rattlerbb01
TX/LA Database Admin
Boerne, Texas
A few years ago Webb SO used VHF Conventional and the GATRRS system (TXDOT and Middle Rio Grande fund the local towers in South Texas). I haven’t been within range of them in quite some time to give the latest. They weren’t encrypted then, but the way things are going down there it’s only a matter of time.
chinnesse
Texas
Yea no there not encrypted yet wanna try to get better signal with a higher antenna i have set up waiting for some connectors to get here.
I post frequency not sure if there is a control frequency . but i hear three simultaneous audio at the same time . And some times here DPS to on county frequencies.
tyler3328
Webb So is on GATRRS TRS. I was just down there the other day and was RXing them no problem. They DO have encryption capabilities easily accessed via a switch.
chinnesse
Texas
Yes i hear local dispatch once a while and sherrif dept. dispatch o but no mobile units i still continue searching .
