ProScan: WebServer No Audio?
burgus
Stronghurst
I'm running on a Win 10 Computer. The scanner (SDS200) is connected by cable to the router. This computer is running ProScan (The Latest Version) is connected by wifi.
I can see the scanner faceplate on ProScan. And the audio tab shows a feed. But every time I try to start the webserver it says
"Set the input sound device To a valid input Located in the Audio Tab."
fxdscon
¯\_(ツ)_/¯
You need to set the audio input url as well as the scanner url.... ---> in the "web server" tab under the "audio control tab".
1677720268446-png.137455
