Weird Constant Static (Help Please)
supraman762
Norman, OK 73072
I have a constant static on my feed. It is always the same and shows up on the two left-most bars on the web player. It can also be heard at all times.
My setup:
BCD996XT
RadioFeed
my feed is located here:
Norman, Noble and Oklahoma Univ Police Live Scanner Audio Feed
How can I get rid of it? I have tried most settings that I can find to no avail.
Any help would be utilized and appreciated.
Thanks in advance,
Austin
Deziel0495
PE/NB Database Guy
PEI
My setup:
BCD996XT
RadioFeed
Thanks in advance,
Austin
I listened to your feed and it sounded fine. No static. If you click on the "audio bars" in the web player it will cycle through different options.
krokus
Southeastern Michigan
I listened, rather briefly, too. I heard nothing unusual.
I did see two bars of the spectrum flashing, which makes me think that you might be dealing with some type of 60 Hertz hum, from a grounding issue.
W2NJS
Washington DC
Try relocating your scanner farther from your computer. Motherboards generate a lot pf RF hash but usually it only travels 15 or 20 feet at the most, but it can get into your receiver easily.
supraman762
Norman, OK 73072
You might be right about my scanner being too close to the computer. Its 3 feet at a maximum. Its also about that same distance from a cable modem/wireless router. I appreciate the help and will fix this asap.
