Weird issue...
4-crime
NY, NY
Hey guys, I have something weird happening here. Those of you that read my post about my Motorola SSE5000 a few weeks back know that I was having an issue with getting static and choppy RX audio on freqs that come in crystal clear on other radios such as my xts5000's and some vertex radios. I sent the radio to Mancow to have him align it. When I received it back I loaded up a code plug to it and when I disconnected from the computer the audio sounded great. But once I turned the radio off and back on I am getting the same staticky audio. I even tried reloading the code plug again. And again it sounded great but once I turned the radio off it again sounded staticky and choppy. Anyone have any ideas as to what could be going on here or has anyone had an issue like this with another radio? Mancow checked it out and aligned it so I am stumped! Any help you guys could give I would appreciate!
jruta
Nj
Corrupt codeplug? I'm no expert, but had the same thing happen to a radio. Reloading the codeplug worked.
4-crime
NY, NY
I've reloaded the codeplug into the radio a couple times and it sounds perfect. But once I turn the radio off I get choppy RX audio again.
RKG
Boston, MA
So far as I am aware, the SSE5000 is an XTS5000 in a Saber case. Offhand, I can think of no programming parameter that would yield what you have observed. But if you walked into my office with this problem, the first thing I'd do is read the radio and look for any personalities that are strapped either "secure" or "select." If I found any, I'd strap them for "clear" and see what happens.
4-crime
NY, NY
Well I've unchecked the secure option in the CPS and still doing the same thing. This is very strange.
4-crime
NY, NY
I just tried something else for kicks, and it seems that if I even just read the radio and not write a codeplug into the radio the audio sounds great. But once the radio is turned off and back on the static comes back. So it seems just being connected to the CPS changes something.
RKG
Boston, MA
Go back and check each "personality" under the "Secure" tab and confirm or change each to strap for "Clear." (You may have to re-check "Secure Equipped" in "Configuration" to ungrey the secure tab in personality; after you're finished, go back and uncheck secure equipped.)
As I said earlier, I'm speculating about a condition I've never seen before. However, the telltale observation you make is that the problem arises after a power down/power up, and one of the things the radio does at each power up is read the state of the "secure" parameters. Just a guess.
