BCT15X: Weird occasional knocking sound when plugged in.
Ryanwatern
Pasco County, FL
Hello, I have a BCT15x and was wondering what this issue may be or if anyone else has had it. The issue is sometimes when I plug-in the scanner it makes this knocking like sound, and it never lights up or turns on. To fix this issue all I have to do is turn it off and turn it on by on and off button or unplug it and re-plug it back in. The on/off button is the most efficient way to fix as it works every time as to when I unplug then plug it back in it does the same issue a few times back to back. Didn’t know if this was something I should be concerned about or if it is something that could progressively get worse so I figured I would ask.
tvengr
Well Known Member
Baltimore County, MD
Does the knocking sound speed change when you turn up the volume? If you have more than one scanner, scanners can radiate signals which interfere with each other.
JoeBearcat
Uniden Representative
Check the power supply and if bad replace it before you damage the scanner.
vagrant
ker-muhj-uhn
California
If you move the scanner and same wallwart power supply to another room and the same problems persist, your power supply transformer is probably bad. Replace it, or suffer the consequences.
Ryanwatern
Pasco County, FL
I will try that, I have about 20 different power supply’s from other Uniden scanners, or other things I’ve had in the past.
dispatch235
Central Missouri
I have a 15X that does the exact same thing, usually when the electric goes off then back on. Shutting it off and back on like yours and it is normal again. I have several other Uniden scanners that come back on like normal, the 15X just seems to have the problem. All of mine are connected to the same 10amp power supply. I also tried putting it on it's own "wall wart" supply with same results. Otherwise it works fine.
