West Springfield FD
Ejdwyer517
Massachusetts
Does anyone know what CMed channel WS Fire uses to communicate with area hospitals? I have all the local freqs programmed and I don’t hear them at all on any of them. Do they even use CMed? Any responses to this inquiry are appreciated. Thanks.
Ejdwyer517
Massachusetts
garys
Texas
It is likely that they are using a smart phone based app such as Twiage. There are a couple of others, but that is most common. Outside of Boston, all hospitals in the state require entry notification for all ED transports.
cg
Connecticut
When I was working EMS many years ago, request for a patch to Springfield CMED would be made on Med 4. I don't think that has changed but as Gary said, many notifications are taking place via non radio means.
trp2525
I don't know about present day but I can confirm that West Springfield Fire used CMED in the past for ambulance-to-hospital communications. A few years back I was at The Big E for the day and saw them transport multiple patients to the hospital throughout the day. Each time they came up on Springfield CMED PL 100.0 (initially on Med 4 for calling/hailing and then to their assigned Med channel) to give the hospital a report on what they were coming in with.
As others have already mentioned in this thread, West Springfield Fire's use of CMED may no longer be the case in 2023 with all of the changes/advances in technology that have occurred over the years. The CMED system in Massachusetts started back in the mid 1970's when federal grant money was plentiful. Fall River CMED (now Bristol County CMED) was one of the very early adopters of the UHF Med channels in the Commonwealth. The CMED system was initially designed/engineered for full duplex communications but that is no longer the case today. The actual CMED analog radio technology hasn't really changed much over the last 45+ years other than the UHF narrow banding that occurred about 10 years ago per FCC mandate. The narrow banding opened up the additional 10 splinter Med channels (Med 12-102) so there are now 20 Med channels available for use in the Commonwealth.
One thing to keep in mind when trying to monitor the ambulances/mobiles on the 468.xxxx MHz frequencies is that those 16 channels (Med 1-8 and Med 12-82) are "usually" non-repeated (with some possible exceptions) so you are monitoring the mobile radio directly. Per the Massachusetts EMS Communications Plan "Subscriber radio equipment shall have, as its maximum transmitter output, a power of between 25 watts and 50 watts." In reality what that means is if the ambulance has a 25-watt UHF CMED radio with a unity gain antenna, you will probably only be able to hear them reliably/intelligibly if you are within a few miles of the ambulance. If you have a base station/rooftop scanner antenna and flat terrain in your area, perhaps you will hear the mobiles a little bit further out. YMMV
The 16 CMED/Hospital transmit frequencies on 463.xxxx MHz (Med 1-8 and Med 12-82) are much easier to monitor as they have higher power and substantial antennas for area-wide coverage. Med 9, Med 92, Med 10 and Med 102 on 462.xxxx MHz are designated as EMS dispatch/coordination channels and are "usually" repeated (with some possible exceptions) so there is no need to monitor those 4 repeater inputs on 467.xxxx MHz.
garys
Texas
A man who remembers the dual control head Motorola "Memcom" Micor radios! ;)
railrob
Westfield , MA
W. Springfield at least for transporting to Baystate ER uses E-Bridge by General Devices. It is a cell based app that will trigger an alarm at BMC and the comm room operator can see the patient report sent.
