Westchester County - 👨🏽‍💻 White Plains City School District 🏫
Westchester1
So first off forgive me if this is posted in the incorrect forum but I’m not sure where it would best fit.
I am trying to listen to my former school district which is located a few miles away. There is no information on RR or Digital Frequency Search saying whether it’s DMR or not. I got the frequencies from the FCC web site and entered them into Sentinel. The 13 frequencies are in the 400Mhz range. I have them programmed in as conventional and hear nothing. The city’s DPW uses DMR so I’m suspecting the school district may too. There’s nothing else in my area I’d need the DMR upgrade for so I’d hate to purchase that and end up not needing it.
Question: Wouldn’t my SDS200 (or BCD536HP) lock onto one of those school district frequencies and make some “noise” if it was in fact DMR or would it just scan past it ignoring it?
First we can better answer your question if you tell us what school district or system you are trying to monitor.
That said, the FCC site where you got the frequency also will show the emission type authorized, once you find it, you can look it up in the RR Wiki HERE
BinaryMode
2600 dialtone blvd
Give this website a try. Sort by entry and scroll down to the W's. They may be NXDN, at least the school district in my area is. Totally makes since to spend $500+ for a radio in a school district... I figure each school here has about $5K in radios.
KevinC
Encryption
Super Moderator
I'm everywhere Focker!
Reading is fundamental…
BinaryMode
2600 dialtone blvd
"There is no information on RR or Digital Frequency Search saying whether it’s DMR or not."
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
Their only active license is below. Only analog voice emissions appear on said license, therefore it will not appear on the digitalfrequencysearch.com dump. The search queries on that site have been down for quite some time anyway as has been reported on several threads here. Keep in mind although analog only emissions appear on a license doesn't rule out the use of other modes. OP will need to listen and confirm what's in use
Westchester1
That is correct. The license doesn’t provide anything definitive. The mode is the mystery.
Thus the original question.
Program them both in and see if you hear anything. Of course, we don't know if they abandoned that system and went to rentals or IP based services like many districts have for buses either, since the license only has about 9 months until it expires.
k2hz
Rochester, NY
Back to your original post - If you program the frequencies as FMN and CSQ then yes, you will hear digital "noise" if they use any digital mode.
If you hear nothing and there is no record of another license they may now be on one of the many local trunked digital systems so they would not appear in a FCC license search. Many school districts are going to a leased service for better coverage than what they have on a their own system.
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
A mystery that can only be solved by listening/observing...
It's part of what keeps the hobby fun & interesting, doing the detective work yourself to figure out usage. Not every license is going to have a clear cut 7K60FXE for DMR, 4K00F1E for NXDN, etc. Be sure the receiver you're using can cover these modes. Lastly, encryption is never noted on an FCC license either but may be a possibility, yes even with school district ops
Westchester1
Anyone able to monitor WPCSD? I have the frequencies from the FCC but uncertain as to the mode.
