I’ve been seeing them in store since 2018 and was wanting to grab one recently to use for my basic analog only/railroad needs while out and about but noticed the different WA appended to the callsign. Does it still come with the same stuff in the box as the regular 1010? Anything differen in the functions? I found one post one here about a PIN on startup after first buying it so does that mean the firmware is stuck with that disa junk everytime I reset or will buying it from Amazon be the same?
A Walmart store manager living next door to me at the time gave me this info a few years back when I asked him about those Whistler scanner PIN codes, I have no idea if the activation codes have been reinstated again lately or not, and I never did buy one (PIN codes were used by other electronic devices sold by Walmart also)..............................
The activation code will only be needed on the Walmart version (WS1010W) of the WS1010 scanners that were...
(1) Originally sold by Walmart and only during the first 6 months or so that they were offered for sale there a number of years ago (2018),
(2) AND...only if the scanner hasn't previously been used and activated with a code from Walmart or Whistler.
(3) The WS1010W is identical to the WS1010 sold elsewhere except for the activation code.
Back when Walmart started selling the WS1010W they, along with Whistler, implemented an activation code system for that scanner. When you purchased the scanner at Walmart, the activation code would be printed out on your receipt, and you were required to enter it into the scanner when you first turned it on. You only needed to enter the activation code that one time. It was supposedly an effort to thwart theft of Walmart's stock of those scanners.
Walmart's program of activation codes for the WS1010W was abandoned about 6 months after they started selling them. In the event that you should still find one of those scanners originally from Walmart on Ebay, Craig's List etc. that would still ask for an activation code (because it has never been activated previously) - just go to the Whistler website to obtain an activation code.
Customer help and frequently asked questions for Whistler products including radar detectors, power inverters, radio scanners, jump starters, dash cameras and inspection cameras.
whistlergroup.com
Someone else on RR was told the same thing about the PIN code no longer being used:
I bough a Whistler WS1010 off EBay. It's asking me for a pin when I turn it on. I have never seen this happen on any scanner I have had, do all Whistler products have pins? The seller doesn't have the pin. So, did I just buy a paperweight or is there a way to find the pin? Or reset it? Thanks
forums.radioreference.com
This was Whistler's answer to a question about the WS1010W activation code on Amazon back in 2018 (answer verified by Amazon as being from the manufacturer)....
We produce two versions of this model. The WS1010 does not require an activation code but the WS1010W does require an activation code and is sold only at Walmart.
I don't know what the in-store model numbers are now, but the current online listing from Walmart (actually sold by Walmart) no longer shows the model number on the box as WS1010
W or WS1010
WA..... just WS1010:
WALMART ws1010
