Check the
FAA SUA Website to see what airspace is currently active.
You might have better luck with some of these frequencies
226.300 - Viper Common (Adirondack Airspace Complex/Fort Drum)
226.800 - VT ANG F-35s air-air
228.900 - Huntress (NORAD)
234.800 - VT ANG F-35s air-air
235.100 - AR206L Primary
238.900 - AR212 Primary
252.100 - Command Post based at Westover AFB (KCEF)
257.850 - Boston Center ATC
258.200 - NG operations based at Albany (KALB)
259.000 - MA ANG F-15s air-air
259.500 - NY ANG MQ-9 air-air
259.900 - MA ANG F-15s air-air
260.900 - Huntress (NORAD)
261.800 - VT ANG F-35s air-air
264.850 - MA ANG F-15s air-air
267.800 - NY ANG MQ-9s air-air
271.100 - NY ANG MQ-9s air-air
276.500 - AR609 Primary
282.700 - AR206H/AR206L/AR212/AR609/AR631 Secondary
293.700 - VT ANG F-35s Operations based at Burlington (KBTV)
295.800 - AR631 Primary
309.000 - MA ANG F-15s Operations based at Barnes (KBAF)
314.400 - VT ANG F-35s air-air
340.800 - NY ANG C-130s Operations based at Schenectady (KSCH)
348.700 - Boston Center ATC
348.900 - AR206H Primary
349.700 - VT ANG F-35s air-air
360.600 - Boston Center ATC
361.400 - Command Post based at Stewart (KSWF)
379.100 - Boston Center ATC
379.500 - NY ANG Operations based at Syracuse (KSYR)
The MA ANG F-15s out of Barnes were working in the Viper airspace this morning, would have flown right over your location, you would have been able to hear them on their air-air, Operations and the Boston Center UHF frequencies.
If you hear any other frequencies please post them here and we can figure out what they might be.
