jambo
In order to improve your reception, its always better to go with an antenna mounted outside your home. Indoor antennas perform about as good as the rubber duckie that came with your scanner when you bought it . Now I'm not knocking the indoor or rubber duckie antenna, but when it comes to getting better reception do to your location from the site, its always better to have an outdoor antenna when the site is located far from where you live. Also make sure your Attenuation feature is turned off. I know sometimes that will cause bad reception on some systems as well.
