I uploaded my new channel programming with FreeScan. I have no audio when it stops on a channel. On the scanner screen at the SO line there is a 0 at the end. I don't know what that is for either. Can someone please tell me what I am doing wrong?
1) What model scannerOn the scanner screen at the SO line there is a 0 at the end. I don't know what that is for either
Uniden BCD996P2What scanner? What system? Copy the link to the system and paste it so we can check it out.
Yes I did assign quick keys in Freescan.1) What model scanner
2) Did you assign Quick Keys in Freescan?
That S0 and the 0 at the end says that you have programmed a system quickkey 0 and a quickkey 0 for the group in that system.
What type of channel is it, analog conventional or some sort of trunked system?
Does it stay long enough that it might indicate that it is monitoring a conversation, at least 5-10 sec, but there's no audio?
If you use an external speaker then check that it's plugged in properly and if it's amplified check that it has power.
Do you get noise if you turn the squelch down to 0?
/Ubbe
Uniden BCD996P2Uniden BCD996P2
Good scanner.Uniden BCD996P2
ConventionalGood scanner.
Please post a link to the system from the database.
What "System Type" did you select in Freescan?
Push the WX button and check that you really can hear the wheather announcements so that you are not in a bad radio coverage location.It does stay on a channel long enough for a conversation to be had.
Yes, a link to the specific system, as well as what agencies (city and/or county) that you want to monitor would help in determining whgat to add or change.Confusing - but from all your screenshots I don't see any talkgroups ,Then I see mentions of your local (non-Moswin) stuff. It gets really confusing. No where do I see a link to what system you are trying to get - just screenshots.
Unfortunately, a screenshot does not display all the information needed to suggest a workable correction or addition.I forgot this.
