I started posting my info in the ST2 thread, but since the ST2/Scantenna won't work horizontally I figured it was best to start a new thread.
Here's my situation:
My primary listening is as follows:
800 MHz - 40% 5-10 miles away
500 MHz - 50% Local to me
150 MHz - 10% Local to me
46 MHz - Very Little
I currently use a RS Discone with RG6 and F connectors with a BNC adapter at the scanner. My antenna is mounted above the insulation in a peak area below the roof. There are no ducts to worry about. I have about 5' in height and about 12' in length to work with.
Since becoming disabled, I don't have the ability to make the antenna suggested, so I'm limited to a purchase only and have my nephew install it. A kit would be ok for him to install. Unless someone has an antenna construction plan that I could walk him through.
Does anyone know if there is anything within those limitations that would be better than my current RS discone? Is there any type of gain antenna available?
Thanks in advance,
Rich
Thanks in advance,
Rich
