What antenna to buy ?
STICKY1
geneva ny
Iam sorry it's RG6 in the wall for cable tv can I use that all the way through to the attic it will be around 50 to 60 feet altogether
davenlr
North Little Rock, Ar
Yes. The ST2 comes with RG6. Just use a double female F coupler between the antenna cable and the wall cable, and you will be in business.
davenlr
You shouldnt need to worry about it unless your run is over 100 feet. Preamps, unless you are very specific in getting one with low noise, and bandwidth that covers scanners, will cause so much interference and intermod that you will regret it. 100ft of RG6 at 900 Mhz is only about 6db loss. The only way I would consider one, would be if I lived way out in the country, with no transmitters nearby to cause interference, AND if you were able to pick up your desired station(s) with the scanner in the attic, but NOT with the antenna in the attic after running it through the feedline.
My ST2 with the coax run is able to pick up repeaters on UHF 60 miles away. While putting it in an attic will cause a little attenuation of the signal, I dont think a preamp would be nessessary.
STICKY1
geneva ny
Ok I think iam gonna do that then the ST 2 is reasonable price 50 bucks on ebay and I got lots of coax in the walls this way I can move the scanner to different locations in the house if need be thanks for the help guys !!!
