DavidNVA
I occasionally hear a unit mark up with the prefix "Scout" before the unit number. Just curious what sort of unit this is? Is this an unmarked unit or something else?
-David
-David
DavidNVA said:I occasionally hear a unit mark up with the prefix "Scout" before the unit number. Just curious what sort of unit this is? Is this an unmarked unit or something else?
-David
The previous posts hit the nail right on the head - and it is a hold over from their previous radio system, where the system would sometimes cut off the first bit of a transmission, so all you'd hear is "...Hundred adam" instead of "Four Hundred adam", so they started using scout and car, because who cares if that gets cut off. Not as much of a problem with the newer system, but it just never got removed from the GOs - at least that's what a dispatcher told meatlong said:Thank you all for asking and answering that question! I've been meaning to post this myself for months and now I have the answer and you're right, it could be a lot simpler. Probably a hold-over from a previous time/radio system. Thanks again.
