What are the "church bells" sound on 7.0874mhz?
beamin
I heard this at 10:51EST in the suburbs of washington DC using DSB with a 68' longwire antenna. Are they a numbers station? They sound like church bells but with no decay, just jumping up and down in tone.
wa8pyr
Technischer Guru
Moderator
Ohio
All I see is JT65 and JT9. Set your computer clock within 2 seconds of a standard time and you should be able to decode it correctly with WSJTx
WSJT Home Page
I agree. JTxx looks and sounds as the OP described.
Pretty cool mode. Really fun for weak-signal work (I think it was originally designed for moon bounce).
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Yup, and it should be noted that JT65 has 3 variations, from what I've read - JT65A, B and C. If it is JT65, MultiPSK will handle it along with WSJT - if it's JT9, MultiPSK won't cut it, but WSJT will...
Mike
majoco
New Zealand
I'll have to download WSJT, some really big signals here at 0520z/1720local on the gray line, 7076kHz. Other good DX too from all over Europe.
beamin
Is there an easy way to record from sdruno using widows 10 and vbcable?
beamin
WSJT Home Page
So I got that up and running I think. I have the sdruno using its output as vbcable. wsjt's input as vbcable and speakers out. The water fall is doing something but no sound. Is that normal? I set it to whisper and set the sdruno to the low frequency LW band. How do I know if its working? Do you have to mess with the sdruno every time you want to change frequencies?
kk6jtl
US West Coast, not California
Your sound setting look right.
Set it to "JT9 + JT65" and leave the sdruno on 40m 7.076MHz USB at night, 20m 14.076MHz USB during daylight.
At :45 seconds into a minute, the computer stars decoding what it received from :00 to :45
By :55 seconds, you should have decodes if someone is transmitting.
At :00 seconds, responses to the last set of transmissions begin.
If JT9+JT65 works, then switch over to LW frequency and WSPR. Wait. It will come if there is something.
