what are the setting for wyolink
wyotrucker1
mikeh said:
what are the VHF setting for wyolink with my BCT396
they are not the same as the pro96
i tryed
What settings are you looking for? I have everything on mine set for "auto". Not much activaty on WYOLINK yet. They are still in the testing stages, there are only about 20 TGID's so far. And they are all WYDOT and Radio Techs.
Ted
mikeh
fremont calif
what are the vhf setup base and offset
what are the vhf setup base and offsetin my bct396
like sd system 157.00 158.00 n and the offset
thank yor the help
mike
mikeh
fremont calif
what are these setting for the bct396 for wyolink
VHF MULTI TABLE FOR THE PRO-96
CH LOW 8192
CH HIGH 12287
OFFSET 8192
STEP 2.5
Expect multible tables.
what are the setting for bct396
hankv
i tryed
Wyolink is listed as a Project 25 Standard System. It should not need a Base, Step, or Offset on a 396. Just set it as a Motorola P25, not Motorola VHF.
mikeh
fremont calif
so no need to put setting
ok that interesting you do not need to put setting in wyoling
that is inresting because some system do like the
sd Vhf system you do needs to set up the base and offset
are you lisyening on you 996
and dose it work ok for you .
mike..
thank you for the help.
hankv
mike..
Mike,
South Dakota uses a Motorola Type II VHF System which does require Base, Step, & Offset. It's programmed as Motorola Type II VHF in the 396.
WyoLink uses Project 25 Standard which you program as a Motorola P25 in the 396.
The key to look for is in the System Type listed near the top of the page.
With System Type: Project 25 Standard The 396 is programmed as Motorola P25 no matter which frequency range is used.
With System Type: Motorola Type II The 396 is programmed as Motorola Type II ???, where ??? will be VHF, UHF, 800, or 900 depending on the frequency range. Only VHF & UHF need a Base, Step, & Offset.
I have both types of systems near me and the 396 picks them up.
kd7gxu
Archer, WY
Wyolink
I heard one of the snowplow drivers using digital today. We were driving down US 85 from Torrington and we were listening to 156.105 PL 107.2. We were listening to the analog highway department dispatch but you could tell from the audio that the plow driver was coming in through Wyolink. I still have yet to hear anything directly from Wyolink, and I had to keep my hands on the wheel rather than try to get my 96 hooked up. Did anyone else hear what I heard today?
3mary2
Las Vegas, NV
I have a PRO-97 so what are freq's so I can program the WYOLINK in my scanner. And how soon will the highway patrol beswitching? Would I be wiser to program the old freq's for WHP at this time. I am from out of your wonderful state and only come up there for two weeks each summer. I am trying to program my PRO-97 for this year as well as a PRO-95 for my sister in law. She love to listen but not to wise when it comes to new things like programming a scanner. Thanks in advance for any help
hankv
3mary2 said:
I have a PRO-97 so what are freq's so I can program the WYOLINK in my scanner. I am trying to program my PRO-97 for this year as well as a PRO-95 for my sister in law.
I don't think either the PRO-97 or PRO-95 will do WYOLINK because it's a Project 25 Standard System. :(
kd7gxu
Archer, WY
scanner for Wyolink
The PRO 97, and PRO 95 will definately NOT work for Wyolink. But they are just fine for almost everything in Wyoming and Wyolink is not likely to be in use anytime soon so if you are visiting this summer bring the 97 and the 95.
