What cable do I need? Hand-held control head to vehicular adapter
ElroyJetson
I have a hand-held control head and a vehicular adapter for Jaguar 700P/7100 radios.
I need a cable that interfaces the two together.
I am presuming this is possible.
What's the part number of the cable I need, and does anyone have a spare?
I have a good number of assorted Orion cables available as possible trade.
Elroy
MR-EDACS
Florida
You can make the cable your self it is easy. The pin out on the hand held controller is the same as on the regular orion control head. On the MRK Yahoo group there is a diagram in the manual in the files section to make the cable. You will also need to set the dip switches on the bottom of the charger witch is located behind the small plastic cover. Dip switch settings are also in the manual. I have made several of these units using the charger for the P7100 and a hand held control head in to Pelican cases for the FHP a couple of years ago. Second thought see attached PDF file.
MR-EDACS
Florida
never mind the file is to large for this forum to upload. Just see the one on the Mrk Yahoo group.
w0fg
Decorah, IA
ElroyJetson said:
What's the exact name of the group, please? I didn't find it as MRK or MrK.
I did find an Orion group, though.
Thanks,
Elroy
The group name is "M-RK"
ElroyJetson
I suppose I could make that cable. But frankly I'd rather buy the factory cable if it's not too expensive. I don't love building cables and it's easier to order one and it shows up on your doorstep a few days later by magic.
However...I expect it will be too expensive for what it is so I'd better warm up the soldering
iron and crimping tool!
Elroy
ElroyJetson
I identified the specific cable I need. The cost is reasonable to my way of thinking, so I just ordered a new one. No hassles and no worries. It's under warranty. I can't say that about a cable I'd build myself, though I do build a good cable.
Elroy
jparks29
John McClane
Nakatomi Plaza
Yup, it's supported by the factory, and you are correct......
It'd be 'the same' as using a W7/O7 control head off of an Astro Saber/XTS AVA, but of course /\/\ doesn't have that... ;)
