What Coding? What Speed?
aka_ramon
Sooo... I'm listening to a system with P25 coded voice, either conventional or trunked, on my 396t.
Does the radio provide, anywhere, an indication of whether the signal was C4FM or CQPSK? And the bit rate at which the data was decoded?
I can't see this anywhere, and I think it would be interesting, at the very least...
w8mkh
Parkersburg West Virginia
Not that i am aware of.. I looked for the same when I got my396
f+volume twice you get the setting for the audio for p-25
markab
Cambridge, Ontario, Canada
Decode threshold
Actually pressing func+rotary knob twice displays the decode threshold voltages. It has no relation to the volume.
Regards,
Mark'
Voyager
n8uxf said:
Thats digital error rate and auto decode threshold start level and decode threshold levels not voltages
I'll bite. If it's not a voltage threshold, what is it that is determining what is or is not below or above the threshold?
(answer: It is a voltage, and the threshold is based on those voltage levels of the incoming data (which is originally a frequency, but is converted into a voltage, or set of them, by the discriminator).
Low Low | High Low | Low High | High High
The | lines (where I put the arrows) are the settings you are seeing on the display. The center one is the center frequency of the carrier. You can also look at it this way:
_ ... --- ''' (four levels)
Joe M.
