Neutrino222
- Joined
- May 4, 2022
- Messages
- 103
Is there anything interesting up in the 894-960 & 1240-1300 MHz range? If so, what kind of antenna would be best for the types of signals up there?
What scanner/receiver are you using to go above 1Ghz.
In the 902-928 range are radios as the Motorola DTR series (digital, frequency hoping, spread spread spectrum). These are commonly used in businesses and retail outlets. It takes one to actually listen to one, assuming they are using a public talkgroup.
Also in that same range, you might stumble across an old analog cordless phone, but those are probably mostly gone.
LMR uses at least down south include utilities companies, chemical/petrochemical plants and some large hotel/resorts, often in trunked systems.
There are also wireless speakers and headphones using analog with a WFM bandwidth on maybe 6 frequencies near the middle of the 902 - 928 ISM band. They are wideband so they can carry a typical stereo signal.There may still be some 900 MHz cordless phones around.
