what do I need?
Gamble
orange county 10930
for the most basic and cost effective but not cheap as in crappy setup to listen to the following frequencies in my area? Thanks for your help. I'm totally new to scanners and radios etc but am getting into the mindset where I want to hear local police/fire/news stuff if necessary. Is there such a thing as this, which a novice like me could use:? --a small unit that sits on my desk, it has a display and some keys , maybe a knob or two, and it lets me punch or dial in a freq and voila!? Or is it a more nuanced process which is going to involve lots of work and money on my part just to hear anything I can make sense of. I would be willing to spend I guess as much as $250 for a device like that. Possible?
this link will bring you to RR's available frequencies for my area, zip is 10930
Orange County, New York (NY) Scanner Frequencies and Radio Frequency Reference
Apologies in advance if the protocol is off with this post
sjlamb
Sarasota County, FL
Gamble
orange county 10930
Thanks so much! It looks perfect except I use a Mac, which sounds like it will be a problem...am I wrong on this?
thanks again,
Gamble
gmclam
Fair Oaks, CA
Welcome to RadioReference.com, you've come to the right place!
You might already have something sitting on your desk that will do the job without much additional effort or cost. Have you looked here? You can select what you want to hear and listen with your computer.
While you can just key in a frequency on most scanner radios and start to listen, there are types of radio systems out there which require quite a bit more programming of the scanner. Many of us now use computers to program our scanners because it is too much work to enter all the stuff needed directly in to the scanner to receive these systems correctly and as we desire.
Yes. But don't spend it all on the radio. You'll need to consider the additional costs for things like: AC adapter, programming cable, programming software, outside antenna & coax, and possible subscription fees.
jrholm
Big Bear
Since the majority of the freq's in your area appear to be analog still you should be able to find an affordable scanner. Look at the wiki here under scanners and see what you like.
