What does "con" mean on the 996P2
scosgt
When trunking DMR?
On a DMR system, clearly trunking because the CC and voice channel show switching back and forth while the TG stays active, but next to the Freq it says "con".
So what does that indicate?
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
CON indicates a Connect Plus system.
CAP indicates a Capacity Plus system.
DMR indicates conventional DMR.
DT3 indicates a DMR Tier III system.
This link explains DMR as it pertains to Uniden.
scosgt
Thank you so much, that explains it.
The Whistler does seem to decode the DMR a bit better, but of course does not trunk track.
Still playing with the threshold settings.
The big advantage of the SD based scanners is capacity. I tried to import all the listed Manhattan DMR channels, there were over 5000 and it would only take 1000 in a group.
