Hey I was wondering what it means by CSQ under the tone category?
If the RRDB tone field is blank it's usually because nobody has submitted a tone or confirmed that no tone is used, but you can't rely on the database being accurate.I'm not for certain but a tone shown as Carrier Squelch may also indicate no tone is known or was found but I think they leave the field blank if the tone if not know.
an example where no tone, csq is used is PT 2 PT. 155.370. Agencies want everyone to hear. Now your item of interest, possibly the tone the dept uses is the same tone that they may use on other frequencies. If the system being used is old, they may only have the ability to use one tone, as a tone board was added and that left no way to change tones, or if these is a fire dept, or volunteer fire unit, they may only have one tone available, and others in the county just follow suit and use one tone too. You personal scanner may be able to do a tone search, and tell you if a tone is being used. If you are far from other agencies, and you are listening, you really don't need a tone.
CSQ = carrier squelch, which means no tone is used.
Does Moswin still have an analog point to point patch running? They did but I forget the TG number used. Today, Troop C seems to only simulcast point to point traffic on TG 5 or 7 it seems and only when they are involved in the transmission. It seems Troop C somehow blocks regular point to point transmissions if they are not a part of the transmission. If someone calls Missouri State on point to point or MO State initiates the point to point call, they are also heard on TG 5 or 7 (in Troop C's case anyway) but if Hazelwood calls Ferguson (an example) it seems like that never comes out of Moswin's repeaters. I wonder how they do that. It seems like a lot for a dispatcher to remember to patch the point to point call into their normal dispatch talkgroups unless their consoles use a different button they press that patches it all together when involved in point to point traffic. Whatever the state does for point to point analog traffic does seem to work well for them as you hardly ever hear any pt to pt traffic on Moswin if state is not involved. I also still hear the KAA203 callsign announced sometimes when they use point to point but not always.
They could have something simple like a light that comes on when the transmitter is running in analog mode on low band or point to point.
Sometimes you can hear some really far away users when they do use point to point from Troop C. Not nearly as much as can be heard on Slater though.
In Region E (just south of Region C), the old MO Sheriff's Net and Point-to-Point are not used anymore. All traffic is on TG 3525 - Region E IO Calling - and is quite busy. Since there are multiple PSAP's in Cape City, there are at least 2 monitoring 3525 24/7, I will hear all traffic from all stations on that TG wherever they are located at. I think that TG 5 and 7 in Region C are just MHP dispatch (Metro and Rural) - you want to monitor TG 3515 which is Region C IO Calling. It isn't a "simulcast" in Region E - all the PSAP's have a MOSWIN radio provided by the state for this - even if the agency isn't on MOSWIN.
