What equiptment is required to upgrade ROS and DSP in a radio
Seadoo
Hello, What equiptment is required to upgrade the ROS and DSP of a motorola astro saber III radio. Thanks
N4DES
Retired 0598 Czar ÆS Ø
South FL
$400.00 SmartRIB and programming cables, a refresh dongle with at least 1 flash on it, a CD with a correct .cvn file for the correct model radio and about a 1/2 hour of patience.
Seadoo
Thanks KS4VT, Do you know where i can purchase the SRIB or is that the price for the srib from motorola ?, I am waiting on a call from Motorola. Says they can take up to 24 hours to call me back. then I plan on buying the newest CPS software and flash keys for the 4 radios that we have they are not up to date. At least six of the 10 radios We purchased were already good to go, so we were able to at least impliment some of the new units and remove some of the older ones. Thanks in advance
N4DES
South FL
As far as I know, you can only buy a SmartRIB from /\/\ and that is the approximate cost.
grem467
Houston, TX
@ 75.00 a radio for firmware, plus the cable, plus the CPS, plus the SmartRib, it might be more cost-effective to take the radios and have your local MSS order the flashkit and have them do it.
There also might be members here that could do it for you as well..
EDIT: forgot to ask, make sure they are 1meg astro sabers before ordering... if in doubt, post your HOST/DSP.
