What feature spec....
blueline_308
Eastern, NC
...will tell me if a radio will recieve I-Call? I have heard that the Uniden 246, 396 and 996 are the only ones that will RX I-Call, but when I read the specs, I see no mention of I-Call. Is there another term for it?
Forgive me if this isn't the correct forum for this question.
Thanks,
Jim
safetyobc
South Arkansas
Most modern Uniden Trunk Trackers will recieve I-Calls. Also known as Private Call.
It is in the manuals of the respective scanner.
The 246, 330, 396, BCT15, 996, 796, 296, and many more do receive I-Calls
safetyobc
South Arkansas
blueline_308 said:
OK, Thanks...so the only Base/Mobile units that qualify are the 996 and the 796...is that right?
Jim
And the BCT15, BC780XLT, BC785D, and probably the BC895 and 898 but am unsure about the 89x models. Also the BCT8 I think,
Dubbin
Findlay Ohio
I don't think the 895 does but don't quote me on that.
