What frequency channels are they using?
JimBobTerp
Easton,PA
Hi
I live in Tamaqua,PA not that far from the railroad tracks and I’m wondering why I can’t hear transmissions of them talking? I have an antenna and I have all the frequencies programmed in my scanner and it never stops on a channel when they are going to talk. Can someone please help me out on this.
James
murphcc1
How far?
Any hills in the way?
What scanner?
What Antenna?
What freq do you have loaded?
Passenger trains or freight trains?
KC3ECJ
Hi
James
Which railroad(s) is it?
murphcc1
How did you program it?
Sentinel?
Not totally familiar with that model.
BUT, do you have the SERVICE TYPE section in the radio, you should have RAILROAD turned ON.
murphcc1
Menu......
SERVICE TYPE........
RAILROAD-ON
JimBobTerp
Easton,PA
Menu......
RAILROAD-ON
Sentinel?
Let it do it by the ZIP Code and I guess railroad and like I said it has every railroad frequency and I do not know exactly what railroad system it is
murphcc1
ok.....you need to make sure the SERIVCE TYPE is on for RAILROAD........
Just doing it by Zip Code doenst mean it's ON.......
And how did you know they were talking?
(got that from WTP)
JimBobTerp
Easton,PA
(got that from WTP)
When I get upstairs I’ll check and see if I have it turned on but I know I was just wondering if they were talking that’s all
murphcc1
If your RR line in that area is straight through with no yards or anything they may just not have anything to say to anyone during that section of the trip.
DudleyG
Lexington, Ky
It appears that the railroad that runs thru your town is the Reading and Northern. You can go to the Radio Reference database, click on Pennsylvania, then click the section for statewide frequencies, and select Pennsylvania Railroads and it will list all of them by railroad. Scroll down close to the bottom and you will see the 4 frequencies that Reading and Northern uses.
Since it is a regional railroad, there may not be much radio traffic.
KC3ECJ
I get the Reading and Northern Pittston yard on 160.770 I'm not sure what Norfolk Southern in Taylor is using now.
trentbob
Silent Key W3BUX
Bucks County, PA
This is a very small Regional Rail Road that probably doesn't have a lot of radio traffic. I remember them also doing excursion trips also in the summertime. I don't know about now.
They're headquartered in Schuylkill County near you. Just put the frequencies in and monitor and see what happens. With the information I gave you if you want to do searches on your favorite search engine you will probably find a lot of information.
By the way if you hear a lot of traffic it isn't necessarily this Railroad, some of the frequencies are shared, 160.8 is a very common Freight frequency used everywhere.
RichardKramer
Reading, PA
If you have all the RR freqs programmed you should be hearing something with an outside antenna. NS is pretty busy on a # of freqs here in the Reading area. Weekends are not so busy as they are on weekdays.
KC3ECJ
I think what happened was I bumped the lockout button for the channel I assigned to Norfolk Southern.
