If you press manual, you can then scroll through the scanlist (the default save to, is scanlist 1) with the up/down arrows. You can also use the Find feature. press Program, Edit, Find enter a alpha text or frequency. And you can find it by object type by pressing Program, Edit, press left or right key to select the object type, such as CONV, the the up down arrow to select the conventional object.
