What is a Good 800Mhz Mobile antenna??
bud229
Gladstone, MI
Looking for some input out there what is a good 800Mhz Scanner mobile antenna?
I live in Michigan and I have a scanner in my truck and I have a cell phone magnet mount antenna
it's only about 4 inches long it is old it picks up a good when I stop but when I am driving it cuts out
a lout when they are talking.
They all talk on 800Mhz digital here.
I have tried a a taller cell phone antenna but did not seem to make to much difference.
Any one know write me back and let me know.
W8RMH
Feed Provider Since 2012
I have been using the Laird Tech TRAB7603 phantom antenna. This antenna has been remarkable. I use it on a mag mount on the roof of my Tahoe (free from hitting trees and such). I even used it on the inside rear deck of a rental car while on vacation with good results.
I have not yet been able to find a dead spot. I get 5 bars on systems I couldn't even receive before. I have used it all over the state, mainly to monitor our new 700/800 MHz P25 system, as well as my county and old state Motorola Type II systems, plus local P25, VHF, and UHF systems when in their areas. I am also seeing them popping-up on new police cruisers.
Here is the narrative from the ad, and it couldn't be farther from the truth -
The Phantom antenna provides low visibility with a wide bandwidth and low angle radiation pattern that can produce results superior to many high gain antennas. Made from high grade plastic. 2.7" high. Requires a ground plane
W2GLD
Michigan
I'll second the Phantom antenna for 700/800; there's nothing better on the market. The key to its success though is actually using a 3/4 NMO hole mount; if you're using a magnet mount, don't even bother as you'll be wasting your time. These antennas require a proper ground plane.
Another good choice is the Tri-band Larsen with a good NMO mount.
DisasterGuy
Maryland Shore
I will add another comment in favor of the Laird 700/800 phantom. It is the spec antenna I use for all public safety installs. Note that while it does a fantastic job on those bands as designed, if you scan anything in VHF it will be completely deaf.
http://www.theantennafarm.com/catalog/laird-tech-qw8253-3281.html
I use one of these on my truck for accessing the trunked system at run at work. It outperforms the quarter wave antenna I used to use. It's a bit cheaper than the phantom antennas and by design, should outperform it. The higher gain allows me to connect to the system from places I couldn't with the 1/4 wave.
I run these: http://www.theantennafarm.com/catalog/larsen-nmo800-902.html on a number of our mobile installs where we want a higher gain antenna with a spring.
Quarter Wave antennas that I use on our bus fleet:
http://www.theantennafarm.com/catalog/larsen-nmoqw800-5936.html
LIScanner101
Palm City FL
My favorite - even works great on VHF and UHF:
DPD Productions - Scanner, Aviation, NOAA, Low-Band, 700 MHz Public Safety, Base & Mobile Radio Antennas for Commercial & Hobbyist Applications
bobmich52
my vote is for the Larsen 150/450/800 nmo.
works great on all bands, even low band with my HP 1 here in ct
it is mounted of the front 1/4 panel of my 2012 Tucson, very low profile
bud229
Gladstone, MI
800Mhz antenna's
Hey thanks for all the info every one.
I will have to decide what one I am going to get.
I have tried cell phone antennas for the 800Mhz digital scanner but it seems like the gain just is not there it still cuts out.
I know on a lout of the police cars around here that I see they have the antennas that look like the
Laird Tech TRAB7603 so they must be working good.
teufler
ST PETERS, MISSOURI
I'm using a larsen nmo 800, ms3e800. Its a gain antenna, 3db, there are several that have a pig tail curl in the stinger that work good also. Do a search, larsen 800mhz gain antenna and you find several styles. Mine has a shock spring above the coil, then a coil in the stinger. Its about 1 foot tall. Had it originally for a mobile radio that trunked through arkansas, tennessee, louisiana and mississippi. Worked good, now use it as the mobile scanner antenna for 700-950 mhz.
k8tmk
Stevensville, MI
I built a 10-element yagi antenna that was in an issue of Popular Communications magazine a few year ago.
Yes, it is directional, but it was cheap to build and works great!
They also had plans for a couple of other yagis with less elements, but the 10-element model is only about 3-feet long, and the elements are only about 6-inches long. I have it end-mounted on the side of my tower.
Randy
LIScanner101
Palm City FL
verhoffj1
Lakewood Washington
so what you're saying is you didn't have any issues with having a magnet mount on an antenna that requires a ground plane?
N3JI
Dallas-Ft. Worth
Kind of an old thread...
The roof of the Tahoe = the ground plane. Still, not a big fan of the salt & pepper shaker antennas myself.
verhoffj1
Lakewood Washington
[Q/UOTE=N3JI;2379397]Kind of an old thread...
The roof of the Tahoe = the ground plane. Still, not a big fan of the salt & pepper shaker antennas myself.[/QUOTE]
could you recommend a good 700/800 megahertz mobile antenna?
N3JI
Dallas-Ft. Worth
I personally use a mag-mount 3dB for temp use, and I have a 3dB on-glass mounted on my truck. They are cut for 800, but still receive well on 700. Got mine from Tessco, and are made by PCTel.
