The GE searcher. No selectivity to be found. Every VHF frequency in the area had the ability to stop scan, regardless of where the tuning knobs were parked!
It was neat. I was bummed that it was a dud.Wow, neat concept, even if a flawed implementation.
The GE searcher
I wholeheartedly agree with you, that scanner series is a PITA to program. They are EVERYWHERE though. For being such a pain to program, everyone bought them. An ambulance agency I worked for even had one wired into their dispatch consoles to monitor fire/PD.Handsdown the Uniden BC-350a.
RigPix Database - Bearcat/Uniden - BC-350A
Using it was torture.....no direct frequency entry and if your freq was 15x.xxx you had to hold down the up or down button until your finger bled and it finally came across the freq before you could save it into memory.
Now add in the memory bank structure was stupid....you had to lock out hundreds of search frequencies before you could save frequencies into the 20 ch police bank and 10 channel FD/EMS bank or else risk getting the scan stuck on one of those search freqs.
Now add in the fact that the scanner had a tendency to loose all settings if removed from power for any length of time which mean you had to redo all of the above.
Now top it off with poor selectivity/sensitivity and you have a POS scanner destined for failure.
God I hated that damn thing with a passion.
I like mine for traveling out of the area.Handsdown the Uniden BC-350a.
The Bearcat BC100…first programable handheld. Unbelievably bad…bad programming, bad buttons, bad batteries…HOWEVER, I give it a pass since it was the first and the effort was there and frankly we would not be where we are today without a first..View attachment 165349
