Close Call® RF Capture Your scanner’s Close Call feature lets you set the scanner to detect then display the frequency of a nearby strong radio transmission such as mobile and handheld two-way radios in areas with no other strong transmission sources. However, if you are in an area with many transmission sources (such as pager radio transmitters, multi-use radio towers, traffic control devices, etc.), Close Call mode might not find the transmission you are searching for, or it might find a transmission other than the one you are searching for. Close Call mode works well for finding frequencies at venues such as malls and sporting events. You can set the scanner so that Close Call detection works “in the background” while you are scanning other frequencies. You can turn off the Close Call feature and scan normally as well as turn off the scanning function and look for Close Call transmissions only.
