K4EET
Chaplain
Seeing how popular my other thread was on CB Radios, I thought perhaps we might take a look at CB Radio Antennas for both the Base Station and the Mobile installations. My criteria for the antennas are:
The Wilson 1000 antenna with a 3,000 watt rating has always amused me. The Wilson 1000 comes with 17 feet of RG-8/X coax with a soldered PL-259 connector. What is amusing, while all of the materials seem to be of decent quality, the coax itself (manufacturer unknown to me) is rated somewhere around 700 watts maximum at 27 MHz using the Belden RG-8/X specification sheet found at:
https://static.dxengineering.com/pdf/Belden RG8X Date 9258.pdf
So if anybody tries to push a kilowatt or more down the pipe to the Wilson 1000 antenna that can supposedly handle 3 kilowatts, there will surely be a catastrophic failure somewhere in the setup.
So let's see what all we can learn from this thread and see what everyone thinks might be the "best" antennas out there. If you know of any "wild" claims, be sure to point them out too! I'm looking forward to lots of good inputs. Thanks in advance folks!
- Cost is not a factor (within reason)
- Size is not a factor (within reason)
- Antenna gain is important for enhanced coverage
- Power handling need not be more than legal limits for AM/SSB operations (specify maximums though)
- Mounting criteria will be as required for a quality installation
- User comments about performance, durability, appearance, etc. very much appreciated
- Durability is very important (my Hustler CGT-144 ham antenna was on various cars for 25+ years)
