What is I in T field in unitrunker
ronenp
Hi there
What is the I in the T field ?
There is a radio id in the target field but no radio id in the source field
SRSP2282
Alachua County, FL
From the Radio Reference Wiki: Column "T" = "Type" which would be [G]roup or individual (iCall)
UniTrunker - The RadioReference Wiki
In other words a "private" call between two individual radios.
Not sure what to make of that... Unitrunker shows both radio IDs when monitoring I-Calls on my Motorola Type II SmartZone system.
ronenp
So why i dont see at least the source radio id and the target radio id
after all radio id 1 is tallking to radio id 2 so both id should be seen a thing that is not happening .
Hi Ronen;
You asked a similar question a long time ago.
If the decode rate is low, you will miss the channel grant - which has both source and target IDs. The late entry messages carry only the target ID.
ronenp
I get 100 % reception (the software say health 100)
The CC is strong and no noise
I dont miss ant regular TG i always see both source and TG
but when it come to Private calles it only show the target id
ronenp
P25 Digital trunking
I went to the WIKI to see what is written there that the description i write will be understandable
so it is a Digital Trunking p25 Phase 1 with 9600 Baud Control Channel ....
Hope now it is more clear
I've got a log file for this system. Definitely P25. I did not see any Unit to Unit calls in the log example. However, the system is capable of SNDCP data calls. Ronen, do you see "Dat" under the SVC column on these calls?
