what is LCN # on a EDACS analog trunking 800 megahertz radio system
WJL
Baltimore,Md
LCN
LCN is the logical number and is the order the frequencies need to be programmed to properly track the system. You will find the listings in Radioreference database for EDACS systems are listed in the correct order if it is known.
Radioman96p71
Polk County, IA
I an EDACS system, the frequency is not sent out with the channel grant like Motorola. Instead, the control channel just says "voice call granted on group NNN using LCN X" and the radio must know what LCN X is in advance. Having them out of order or incomplete means the radio wont get any calls that land on the problem LCNs.
P25 systems don't suffer this problem either...
In the Western US Mountains :)
okay thank you all for helping me understand how the system Works ..... so what's the best way to find the LCN ?? As far as I can tell the tower I am trying to monitor has not been uploaded to the radio reference database ?!?!
Radioman96p71
Polk County, IA
That can be tricky.
Your best bet would be to use a program like Unitrunker, which is an extremely powerful tool for analyzing trunked radio systems. From there you can see the activity and the LCN numbers, but NOT the frequencies. You will have to manually find those. The way I do it is either look for the FCC license for the system in question, and then put all those frequencies from the license in a scanner. While watching Unitrunker, when a call comes in note which LCN its on, and then see what frequency the scanner stopped on.
You can get lucky after a few hits and maybe notice a pattern to the numbering. (one system near me uses 5 frequencies for LCN 1-5 from 856.5875, 857.5875 thru 860.5875) The unlucky alternative if you have no idea what you are hearing is the same method, but set your scanner to search the whole band from 851 to 862, and hope they have enough activity to let you find them before they move. (a dead giveaway for and EDACS channel is at the end of every analog voice call there is a series of loud BEEP BEEP BEEP that lasts 2-3 seconds, this will be a good indicator you found an EDACS working channel)
Hope that helps, there is a ton of resources over at the Trunking Control Channel Decoding - The RadioReference.com Forums forum here.
com501
Or, you could read someone's radio who is on the system..... THAT's a little trickier.
