I thought there was an LSM discussion page but I can't find it.
LSM is different than P25. It uses CQPSK moodulation, not the C4FM that scanners decode.
Actually, the opposite.
Simulcast systems usually cover larger areas, where there are multiple repeaters needed to cover an area. All the 'repeaters' transmit the voice data at the same time on the same frequency. That's why the scanners have a hard time when the signals arrive slightly out of phase due to distance, multi-path, etc.
Which one is better at decoding signals it was not made to? None. No scanner currently offered can correctly decode LSM. I thought there was an LSM discussion page but I can't find it. LSM is different than P25. It uses CQPSK moodulation, not the C4FM that scanners decode. The unication can decode both and that is why it is the only option to correctly decoding LSM. It's like asking which AM radio can best decipher SSB. Well none are made to do it but some you might let you hear a word or two.
Simulcast radio systems very precisely control the phase of the RF signal to ensure that the RF emitted from each of the simulcast transmitters will arrive with before the maximum delay spread value, through out the intended coverage area of the simulcast cell.
Also concider the doppler effect. When a patrol car are on its way to an incident and they have a transmit tower behind them and one in front them, the doppler effect will change the received frequencies conciderably. Users of simulcast systems will never be 100% satisfied as they always will be the victims of interference from another tower at one time or another. When rushing to an incident the radio communication might not fully work until they stop the car at the scene.
Are there any simulcast systems outside of US? I think it is only the high cost of frequency licenses that have made simulcast systems neccesary. Technically is better to have different frequencies for each tower in a radiosystem.
/Ubbe
This is the correct answerIn a simulcast system there is time of arrival delays, BUT the system is engineered to keep that time of arrival difference to a very narrow amount, a minimum and maximum amount of difference in time of arrival. It’s called ‘delay spread’
C4FM is very unforgiving, and can only tolerate a very small amount of delay until the receivers can no longer decide the data. LSM/(W)CQPSK can tolerate a much wider amount of delay with out losing the ability to decode(by real system radios) the data stream.
While the subscribers are receiving LSM/CQPSK modulation, the transmit to the system in C4FM.
In a properly engineered simulcast system this isn't really the case. The need for simulcast also goes well beyond any cost of licensing (government agencies are exempt from filing fees anyway). Spectrum is a very limited commodity. To use something other than simulcast on a 10 channel trunking system with 10 sites would require 100 frequency pairs. Couple that with the fact that every time a radio would determine it's need to move to a new site (in P25) it would need to deregister and the register to the new site causing a brief drop in coverage. If you have heard complaints about OpenSky systems, it is because OpenSky is engineered exactly as you describe using a cell type strategy of non-simulcast sites.Also concider the doppler effect. When a patrol car are on its way to an incident and they have a transmit tower behind them and one in front them, the doppler effect will change the received frequencies conciderably. Users of simulcast systems will never be 100% satisfied as they always will be the victims of interference from another tower at one time or another. When rushing to an incident the radio communication might not fully work until they stop the car at the scene.
/Ubbe
Have you ever modeled 40dB interference contours in a relatively small county that needs many sites? As a general rule you aren't going to see reuse in municipal or county systems.Not true, given the fact that in any multi-site system, there are multiple sites whose coverage areas do not overlap. You'd only need 10 times the maximum number of sites with overlapping coverage areas. The problem is similar to calculating the minimum number of colors needed to avoid giving adjacent states on a US map the same color. You don't need 50 colors, you can actually get by with 4. The absolute maximum number of unique channel pairs you'd need for any size system is 70, if the sites were arranged in a perfect honeycomb grid on flat unobstructed terrain.
It's not an issue for the thousands of P25 systems that do not use simulcast, or have a mix of simulcast and non-simulcast sites, like Ohio's MARCS or West Virginia's SIRN. It's also not an issue for agencies whose entire jurisdiction falls within the coverage area of a single site.
/Ubbe
