prcguy
Did you put down a layer of electrical tape first under the tar stuff like mmckenna mentioned, like Scotch 33+? You must do this then follow up with a top layer of approved tape for the outer covering and the connection will outlive you. There is a reason for all these layers, it simply works and if you didn't do it all then it doesn't work and moisture will get in. And it will be messy getting to the now corroded connector in the future.
On waterproofing connectors: I once used that tar-like tape, wrapped it around a good length and thoroughly smoothed it out with my fingers. After a few years when I had the need to remove the connector I found out it had gotten a lot more corroded than unprotected connectors--as though the tape inhibited the escape of moisture (condensation). Hopefully there's a better way out there somewhere than that tarry tape...
