What is the cheapest way to monitor DRM Tier 3 on 220 Mhz?
vsp5151
What is the cheapest way to monitor an electric company system using DMR Tier 3 and operating on 220 MHz? That is the only system I wish to monitor.
vsp5151
I can borrow an SDRPLAY RSP-2. How do I decode DMR Tier III
slicerwizard
Toronto, Ontario
You'd need an SDR dongle and a software-based decoder that:
a) decodes DMR
b) only requires one dongle to monitor a TIII system (depends on certain factors)
can either
c) understand and track a TIII system
-or-
d) scan channels without getting stuck on the control channel
Pretty sure that the free DSD+ 1.101 can handle a), b) and d) if an FMP scanlist is created with all RF channels specified as DMR channels; FMP should skip over the control channel unless the second timeslot is carrying a voice call. But that's for one of the cheapie SDR dongles - DSD+ 1.101 doesn't support SDRPlay SDRs.
DSD+ FL can handle a), b) and c) and would work with an SDRPlay RSP2.
I assume SDRTrunk and OP25 can handle a), c), as well as b) if the span of all of the system RF channels fit within the dongle's sampling rate (I don't imagine that 220 MHz system channels are spread across much spectrum, so b) should be a non-issue...); not sure if they support SDRPlay devices and specifically the RSP2, but I suspect that they do. Someone else will know for sure.
dcr_inc
Not an EXPERT !!
Delta, Pa
Bluetail Technologies P25RXII does DMR Tier III decode
sonaalice234
SDR dongle and software-based decoder required
DECODER
1) monitors TIII systems with one dongle
2) track a TIII system
the control channel without getting trapped.If an FMP scan list is generated with all RF channels defined as DMR channels, then FMP should skip the control channel unless the second timeslot is conducting a voice call. But DSD+ 1.101 does not support SDRPlay SDRs.
