I am listening to twinsburg fd talk to aurora fd on their talkgroup and they told them to go to portage county talkaround but its not listed in rr database what frequency are they on or tg?
Portage County Sheriff has a license for several 700MHz frequencies. They're all simplex, mobile only--no repeaters or base stations. See below:
FCC Callsign WQQN985 (PORTAGE COUNTY SHERIFF)
FCC Callsign WQQN985 (PORTAGE COUNTY SHERIFF)www.radioreference.com
The frequencies on the license are:
769.00625
769.01875
769.03125
769.04375
769.05625
769.06875
774.93125
774.94375
774.95625
774.96875
774.98125
774.99375
Based on the emission designators they could be used in analog or P25 mode.
The "portage county talkaround" channel could easily be one of these. In fact, I think that is the most likely explanation of those offered so far. Unfortunately it will take some difficulty to confirm this as you will need to be mighty close to the scene to hear anything. 2 watts on 700MHz from a portable radio at ground level isn't going to carry too much farther than you could yell.
Well, that particular license doesn't include any vehicle repeaters (station class would be MO3). They do have a separate license that happens to overlap with one of those 13 frequencies (774.98125) that does have vehicle repeaters on the license. See below:Are these vehicle repeater frequencies?
Aurora switched from the Geauga 7TA to MARCS MTA-1 for fireground. Aurora was the first community in Portage Co to move to MARCS and it initially appeared that nobody else in Portage Co was interested in making that move. They do a lot with Bainbridge Township and it presented that Geauga 7TA would be the most practical. When the other Portage Co agencies eventually started to move to MARCS, the County template had MTA-1 as the common simplex to use as fireground. Aurora often works with Streetsboro and Mantua and recently chose to switch their fireground (Ch-16) to MTA-1 to be consistent. Yesterday's incident was the first time they used MTA-1 since the recent change.Hi, Aurora FD operates on Geauga County’s “7-talk” channel as their fireground. Yesterday was also the first time I heard the term “Portage County talk around” being used in Aurora. I did tune into 7 talk around yesterday, and did not hear anything, which is not unheard of, but definitely not expected.
I checked what other MARCS talkgroups Engine 1 and the OIC could have operated on, but nothing came up. The incident commander (SRC 6791206) for last night's fire also works in Mantua, where for THEIR fires, they operate on Portage County MTA-1 (mutual aid talk around), also referred to as Channel 16/16 talk around. As of right now, I cannot find this channel anywhere. If anyone has any information about that/how to find it, I'd appreciate it, but I would assume that because of how things are done in Mantua, the incident commander put them on Channel 16, whatever that is.
Hope this helps.
6791206 is an Aurora Fire Officer WT. When they bought that group of newer radios, Mantua bought some a little after and that RID, along with two others, were duplicated in the Mantua FD radios. Somebody at MARCS didn't get an updated list in time. It is not the same person. This was recently discovered and should be corrected in the near future.
Thank you very much for the information. I totally forgot how radio IDs could be duplicated (previously Squad 2 and Car 3 with 6790377) and I apologize for spreading that misinformation. Always nice to find an answer to a mystery, have a nice day.Aurora switched from the Geauga 7TA to MARCS MTA-1 for fireground. Aurora was the first community in Portage Co to move to MARCS and it initially appeared that nobody else in Portage Co was interested in making that move. They do a lot with Bainbridge Township and it presented that Geauga 7TA would be the most practical. When the other Portage Co agencies eventually started to move to MARCS, the County template had MTA-1 as the common simplex to use as fireground. Aurora often works with Streetsboro and Mantua and recently chose to switch their fireground (Ch-16) to MTA-1 to be consistent. Yesterday's incident was the first time they used MTA-1 since the recent change.
MARCS MTA-1: 852.1375 NAC-293
