DO NOT trust an antenna rated by a dBi gain figure!!!
DO NOT ever trust a antenna manufacturer who RATES there antenna's by dBi ratings. If you follow the following you will get an idea why.
I once saw a guy on a website bad mouthing an antenna on his website that he was comparing to an another antenna, a basic dipole design because the antenna he favored had a 2.5 dBi rating and as far as he was concerned it was a GAIN antenna, THOUGH in his review the antenna DID NOT improve his receive capabilities over a basic whip antenna. He blamed it on "conditions" of the air at the time. LOL.
dBd (dB dipole)
The gain an antenna has over a dipole antenna at the same frequency.
A dipole antenna is the smallest, least gain practical antenna that can be made. The term dBd (sometimes just called dB) generally is used to describe antenna gain for antennas that operate under 1GHz (1000Mhz).
The reason why the gain of many antennas, especially VHF/UHF antennas, is measured in dBd is because antenna manufacturers calibrate their equipment using a simple dipole antenna as the standard. Then they replace it with the antenna they are testing. The difference in gain (in dB) is reference to the signal from the dipole.
dBi (dB isotropic)
The gain a given antenna has over a theoretical isotropic (point source) antenna. Unfortunately, an isotropic antenna cannot be made in the real world, but it is useful for calculating theoretical fade and system performance.
The gain of Microwave antennas (above 1 GHz) is usually given in dBi.
A dipole antenna has 2.14 dB gain over a 0 dBi isotropic antenna.
If an antenna gain is given in dBd, not dBi, add 2.15 ( I have seen this number actually vary by different authors, TOO) to it to get the dBi rating.
Example, if an omni antenna has 5 dBd gain, it would have 5 + 2.15 = 7.15 dBi gain.
Note: If an antenna gain is just specified in dB from a manufacturer, be sure to ask if it is dBi or dBd. If they cannot tell you or do not know the difference, then you should consider buying from another vendor! This can lead to over blown antenna performance ratings and expectations
I hope this was easy to follow and grasp.
