I don't see the reverse S on there. See attached for what the reverse S looks like. Notice it's in the same position as the reverse T.
I see that on mine as well. It is usually a signal (or interference of types) that is stronger than the squelch threshold that is not a digital signal the radio can decode. Or a signal of a different mode than the system being scanned.
Turning the squelch higher will get rid of it at times. In my case, it was usually out of band signals, mostly from FM Broadcast stations. I needed FM Notch filter and then VHF paging band notch filters in order to filter out the noise or interference. Once I did all that, the reverse S is mostly gone now on all trunked and conventional systems I monitor.
By default these radios also need the squelch to be set at what seems to be a higher than normal level.
Try entering all the frequencies used by the system you see the Reverse S pop up into a new scanlist and programmed as regular analog conventional with no tones set. Scan those and see if just one or more of the frequencies shows a signal.
If you unhook the antenna now, does the Reverse S go away? If so, that is a sure sign the radio is picking up some kind of signal on at least one of the frequencies it is scanning.
Almost all GRE designed scanners in the last several years have bad front end problems with filtering out FM Broadcast stations mainly. It's almost like they don't have any out of band filtering to kill the strong signals from the FM radio band. An FM trap will help mitigate that. FM Traps are a must here for my GRE designs.
Hope you can figure it out!
