What is this crap from the Page.txt
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Aug 6 11:41:00 MSEL id 7805 closed.
Aug 6 11:42:54 Add2MSEL id 7805, group 59351(?)
Aug 6 11:43:03 MSEL id 7805 closed.
Aug 6 11:46:23 ? 57406 Af-> 59408 ?
Aug 6 11:46:25 Add2MSEL id 7805, group 59351(?)
Aug 6 11:46:30 ? 57406 Af-> 59408 ?
Aug 6 11:46:35 MSEL id 7805 closed.
Aug 6 11:49:19 ? 57406 Af-> 59344 ?
Aug 6 20:25:31 Add2MSEL id 7805, group 59351(Fire EMS Dispatch)
Aug 6 20:26:20 MSEL id 7805 closed.
Aug 6 21:35:08 New Patch id 7711, group 57843(Central Files)
Aug 6 21:35:08 Add2Patch id 7711, group 57683(Police Dispatch)
Aug 6 21:45:10 MSEL id 7711 closed.
Aug 6 21:45:10 Add2Patch id 7711, group 57843(Central Files)
Aug 6 21:45:10 Add2Patch id 7711, group 57683(Police Dispatch)
Aug 6 21:45:11 Add2Patch id 7711, group 57843(Central Files)
Aug 6 21:45:11 Add2Patch id 7711, group 57683(Police Dispatch)
Aug 6 21:45:12 MSEL id 7711 closed.
Aug 6 22:16:03 Add2MSEL id 7805, group 59351(Fire EMS Dispatch)
Aug 6 22:16:27 MSEL id 7805 closed.
Aug 6 22:46:18 Diag 0c45: RIB Malfunction
Aug 6 22:51:50 Add2MSEL id 7701, group 57687(Police Dispatch)
Aug 6 22:51:50 Add2MSEL id 7701, group 57847(Central Files)
Aug 6 22:52:07 MSEL id 7701 closed.
Aug 6 22:55:00 Diag 0a45: RIB Enabled
This is the only type of data on the Detailed Log each time I run trunker. All keys are set to Both.
TIA
WayneH
Forums Veteran
Super Moderator
Your master site
Let me address this "crap" :lol:
1) MSEL id 7805 closed.
2) Add2MSEL id 7805, group 59351(?)
3) Aug 6 11:49:19 ? 57406 Af-> 59344 ?
4) Diag 0c45: RIB Malfunction
1] A MultiSelect (search if it's an unknown term) has ended. This means the console finished its chit-chat broadcast. "7805" 7=MSEL, 805 is what's called the SuperGroup (search if....). The MSEL will be heard on only the Supergroup.
2] This message means TG 59351 is part of the MSEL. If it was a patch it would mean the TG was included OR added to the patch if the patch is running constant.
3] This is an affiliation message; Radio 57406 affiliated to TG 59344
4] "Diag" messages related to system/site hardware status. In this case a RIB (search if...) malfunctioned. There is more to 0x0C45 but it's not important right now.
-Wayne
fmon
Eclipse, Virginia
Thanks for the clarification Wayne. I was racking my "brain" for an acronym for MSEL.
letarotor
Arlington, TX
Found out something interesting yesterday. I was running Trunker on a low end Penitum Satellite Pro laptop which has a rather low capacity hard drive. Every time I hit the "S" or Save button the program would stop running and I would get an error message. Not only that it dumped the identification file. I discovered that my .page file was over 5 million bits and the file had used up all the storage space left on the harddrive! :roll: I deleted the file, turned the logging options off and everything is running smooth again. :D So keep in mind that the program will continue to log entries to the file until you run out of space on the HD. :wink:
