krazzedkanuk
I have a Whister WS1065 setup with 50' of RG6 receiving from a T601 Workman discone mounted 23' in the air above a shed with a metal roof. The WS1065 is setup to scan Bell FleetNet - Ontario Provincial Government Zone 1 Trunking System, Southwest Zone, Ontario - Scanner Frequencies for local police and EMS.
My problem is that the scanner misses a lot of transmissions. I know this because I have a BCD436HP that hits a lot more with its stock antenna inside the shed than the WS1065 does.
I originally thought it was the scanner or its programming so I brought it in the house, hooked it up to a Scantenna on the roof with 75' of RG6. The WS1065 was flawless hitting one transmission after another. So its not the scanner or its programming. It has to be the antenna or cable.
This weekend I replaced the RG6 in the shed with new RG6 with factory compression fittings. Still the WS1065 misses calls. Is the T601 Workman discone not up to job or could it be the metal roof on the shed?
I have attached a couple of pictures of the antenna and shed roof.
Thanks in advance.
Thanks in advance.
