I just picked up an ST2 so I will have it buy Friday and on the tower buy Saturday so time will tell
The ST-2 antenna comes with a 75 ohm transformer into an RG-6 female. This antenna works really well as long as you mount it as high as possible and vertically. I ended up running about 75 to 100 feet of RG-6 into 4 radios and it seems to work really nice without an amp on it. Dont need it. Actually it works better than my Diamond D130J Discone antenna
Thats a nice antenna and plus it have some gain which they are made and professionally tuned. Report back when its installed
That's what I would do, or even better buy a compression tool and put on a bnc connector without any adaptersso you say go buy 100ft of RG 6 and put a bnc screw on type on at the end???
I bought a nice little kit at Home Depot, has the compression tool, coax stripper and cable cutter. The compression fittings are much better than the crimp type and I wouldn't even consider the twist on ones. I have seen the compression BNC fittings at HD too. Amazon has it all too if you like to shop there.That's exactly what I would do...although not sure about the radio end. I'm not sure that there are BNC connectors ready to go directly on to RG-6. And then it must match up to the type of RG-6...quadshield or not.Might be easier to go with F connectors on both ends and look for an F to BNC adapter. If anyone has experience here, please jump in. Also curious if anyone has found a good source for this cable...especially on Amazon. I'm also tempted to start a thread on the tools that are handy for working with RG-6...the crimper and the cutter. I've watched cable and satellite installers do several runs of this stuff and always been amazed at how easy they make it look. Proper tools make magic. Anyone have recommendations on these?
