What kind of Scanner Antenna are you using??
  • Directional; mounted outside
    Votes: 0 0.0%
  • Active; mounted outside
    Votes: 0 0.0%
  • Directional; mounted inside/attic
    Votes: 0 0.0%
  • Active; mounted inside/attic
    Votes: 0 0.0%
  • Other
    Votes: 0 0.0%
  • Total voters
    4
bear105
After researching the latest Antenna options for scanners, I was wondering what everybody else is using and where they are mounted...
JGP
Franklin, Wisconsin
bear105,
I use a Scantenna antenna. This is a very good antenna for my scanning needs. RG6U coax works the best with it.
I have it mounted on a tower 20' in the air. This is high enough that the wind load will not damage it. I use only the top 10' section of the tower with a 10' piece of electrical conduit tubing. Over the years, I found that electrial conduit makes the best mast because it will not bend in the strong winds like water pipe will. Then to service the antenna, I just take out the 10' mask and don't have to climb the tower.
This works for me.
Joel
Franklin, Wisconsin :D
K3WHO
Lock Haven
I'm using an MFJ 1/4 wave 2 meter groundplane antenna setup indoors. It's not the best but it works.
Joseph11
I'm using the antenna that came with my dad's PRO-24 (1995) on my PRO-92 (1997).
radiocacher
Arden, NC
I'm using a Diamond D-130 Discone that I've had for about 12 years. It's been through blizzards, ice storms and high winds and still looks and works great.
brandon
SoCal
I live in apartment and have 3 antennas in the attic.
Scantenna by Antennacraft
Radioshack Discone
Grove Scanner Beam II
The beam works best for recieving the RCS North and Riverside/San Bernardino CHP from El Cajon.
Discone is used for VHF and FedCom listening and the Scantenna is used for airband / GMRS / news monitoring.
banks
CA
Using a Comet 2m/70cm GP-9 17' vert mounted at the peak of my house probably 40 feet up for the past 5 years. Love it. :D
safetyobc
South Arkansas
Scantenna here! Had it a little more than a week....it works okay for me. I am in a very rural area so I can't expect too much. Getting signals at about 60 miles, so it is pretty good.
radioscan
Radio Sensei
Southern Ohio
I have a Diamond D-130 Discone up about 30 feet and a Scantenna about 5 feet off the roof. First priority this spring is to raise the Scantenna up
at least another five feet. C'mon warm weather :D
quatlo
Central NC
An Antron 99 stick mounted 80 feet up in the top of a pecan tree with RG-8 cable and good telco solid copper ground wire attached to two 8 foot copper rods with a jumper between them. Survived at least 10 hurricanes so far.
Central IL
Scantenna, Radshack Discone, Workman 2m/70cm colinear, Astro-Plane 5/8 wave CB/10Meter. Some of these are used for transmitting, but all have been/are used for monitoring. Does my DirecTV dish count? :roll:
K2KOH
Silent Key
Putnam County, NY
Been using a Rat Shack discone with my R7100 for a couple of years now. Just put fresh LMR 400 coax on, and things are fabulous!
NorwalkRXing
Conn.
I'm using a Diamond D-130j, w/ LMR-400 ( 61' ), radio shack # 20-176, w/ RG-6U ( 55' )...both setups have been very good to me! :D
