What kind of sound is this?
Disk4mat
Queen Creek, AZ
Being new, I am not sure what I am hearing on this conventional system. I attached a zip with mp3. Alternately I added the file to dropbox
Dropbox - Gila-NAT7-Payson.mp3 - Simplify your life
I never used to hear this until I moved my antenna to a higher location. The audio type is set to "all". Modulation "NFM"
  • Gila - NAT7-Payson.zip
nd5y
Wichita Falls, TX
It sounds almost like a DMR signal cutting in and out. What frequency was it and what kind of receiver? It could be that moving your antenna to a better or higher location is making strong signals mix and cause intermod in your receiver.
N9JIG
Sheriff
Moderator
Far NW Valley
I concur, it sounds like DMR. If you have a DMR capable scanner try that, otherwise maybe someone else here can check it.
This is a common business channel so there are many other users on this in the Valley. The license (WQEB601) you provided is expired so that user *may* not be there any more.
