The data base is not correct. It says that they are all still analaog. When I click on the ICOORS part where it gives the DEC AND HEX it dousnt give the frequency and most of the alpha tags don’t match up to the frequency list.
When a database admin tells you it's correct, they are typically right. What you are describing is a lack of familiarity with trunking basics, the links and info u2brent posted should help. Read it all and that should help bring you up to speed. When you look at the entry for a talkgroup, the decimal or hex talkgroup is all you need as the system and site frequencies are shared by everyone on the system. They are not unique per user/channel.
The information on the old analog channels persists for now as the switch to digital trunking was not long ago and sometimes the old channels can still be used in certain circumstances. Eventually as it is proven they are not, those entries will be deprecated from the database.
If you do as I asked and update the scanner, all this info will already be in your scanner and programming by hand won't be necessary. The entire up-to-date database will be on your scanner's SD card and by simply entering your ZIP code it will know where you are and scan the things local to you automatically.
