Hello,
Can anyone tell me what is the recommended rate of a 9 volt wall charger for a PRO95?
Batteries are Ni-MH/AA/1.2V/1,800 mAh each.
4 batteries = 7,200 mAh.
Radio takes a 9 volt charger.
Radio shack sells a 9V/300mA model and a 9V/800mA. There is nothing in between that I could find.
I had previously used a 9V/300mA model to charge 4 nicad AA 1,000mAh batteries in a PRO93 without a problem. Is 300mA to low of a charging rate for 1,800 mAh batteries, or is 800mA to high?
As I recall, there was a rule of thumb saying not to exceed X% of the total capacity. I'm thinking is was 10%. If so, then I would be going over the safe rate with the 800 mAh wall charger.
Thanks for your help.
