What the difference between the Pro 197 and the Pro 2096
mrlthse
LAYTON, UT
Greeting,
Looking thru my old records
and I saw a listing for a
Radio shack Pro 196 and then one between the Radio Shack Pro 197
Does anybody know the difference
GTR8000
NY/NJ Database Guy
BEE00
There was no Pro-196. Perhaps you meant the Pro-96. If so, the most obvious difference is that one is a handheld, one is a mobile. You can look at the entire list of Radio Shack scanners in the RR Wiki and compare the differences yourself.
mrlthse
LAYTON, UT
So you are saying what I am reading is simple a "Fat Finger" on the keyboard..
There is no Radio shack Pro 196.
Thank You
Chris K7CDS
mrlthse
LAYTON, UT
I just purchased a (Used) Radio Shack 197
I have a couples of Radio Shack Pro 2096
Question I have:
Has anybody done any real Investive research
between these two receivers.
hiegtx
Dallas, TX
The Pro-197 is a later model digital scanner than the Pro-2096.
The 2096 is a 'banks & channels' scanner, whereas the 197 is an object oriented scanner. The programming of the Pro-197 is more flexible than that used by the Pro-2096. The Pro-197 can handle LTR systems, which the Pro-2096 cannot. The 197 also make use of the NAC codes used by conventional digital channel frequencies. While the 2096 can monitor conventional digital channels, it cannot utilize the NAC.
mrlthse
LAYTON, UT
Lots of knowable monitors out there
would enjoy reading additional inputs
if ya please...
buddrousa
You have been given the differences as they are
1 The change from banks to a dynamic memory
2 The addition of P25 NACS
3 The addition of the 700MHz band trunking
4 The updated 800 trunking rebanding
