Analog vs. Digital vs. Encrypted
Just thought I would answer your questions directly to avoid any more confusion and bickering.
OZ_Redneck said:
If most emergency services that use digital are also encrypted then what can I expect to recieve on digital that im not already receiving?
Nothing. You will hear the same exact thing, either dead air, digital noise, static, etc.
However, it is an assumption that "most emergency services that use digital are also encrypted." Actually, this is not normally the case. There are a few agencies that encrypt everything, but very few. Most agencies that use encryption use it for tactical purposes, such as detectives, surveillances, records checks, etc. Also, the radio techs want to feel special, so many times the radio tech channels are encrypted, as well.
OZ_Redneck said:
On analogue should I already be receiving the digital transmissions as garbled noise?
Yes, when listening on an analog device that does not decode digital transmissions, you will hear the digital transmissions as I described above.
In regards to encryption, as stated by others, no scanner (available in retail) can decode encryption, whether the transmission is in digital or analog.
In regards to buying a scanner that can decode digital transmissions (ie. APCO Project 25 or P25), properly tuned, you would hear all the digital transmissions you were not able to previously hear on your analog scanner, as long as they are not encrypted.
