SDS100/SDS200: What Will Be The Best Way To Program This Into My Uniden SDS100?
JASII
Memory Capacity
The school district that I live in is moving from a UHF 460 MHz Capacity Plus system to 800 Mhz Capacity Max system.
I have no experience with Capacity Max.
It looks like they have two licenses for it under WSEB200 and WSEB202.
I have programmed those frequencies in conventionally to see which of them are active.
Last week I heard what sounds like a home/rest channel on the following frequencies:
854.7625
855.1375
855.4125
856.3125
This morning there is nothing on those, but they might be working on it right now.
Color Code 0 is used on all of those. Sometimes the Digital Type is DT3 and other times it is CON. There are even a few times it shows CAP.
I think all I can do right now is program it in as a MotoTRBO Trunk System, let it run in the ID Search Mode and see what I hear.
I have created a different site for each of the 11 locations listed on the FCC license.
Is there anything else I should be doing to monitor this system?
dave3825
Suffolk County NY
I have nooelec, Airspy and Hackrf. All will work but for just snooping and mapping a system while also using a scanner, nooelec or rtl sdr blog. Even orange flight aware dongles are good. All depends on the end goal, spread of freqs and software being used. So much variation.
