Same setup here. I get excellent coverage on the Phoenix Sub.
In practice the 160MHz 5/8 Duck performs anywhere between 5.0dBd and 5.5dBd. So...close enough.
Depending on the location at the moment I gained an additional 2-4mi of range when I switched my APX portable over from the stock Motorola antenna. Which is saying something cause the terrain isn't really radio friendly in most places around here.
Make your own !
234 (divided by your Freq) Times 12 to convert to inches.
Example for 160.4100:
234/160.4100 = 1.4587 * 12 = 17.505 inches!
Make your antenna 17.505 inches long.
My scanner has a BNC connector, so I used a BNC to female RCA adapter, I just used a wire diameter the same size as the plug hole.
(234 is what you use for a 1/4 wave antenna.)
73's
KC1JPY
And I will bet a fresh roll of toilet paper that a simple 17.5" 1/4 wave whip will outperform the 9" 5/8 wave Smiley rubber duck.
What "prc" says. Find a telescopic antenna with the right connector and make yourself a chart showing how much to extend it for the frequency you want to listen to. Rocket science it's not.
Sorry to burst your bubble, but I've always had consistently better results in the real world with the Smiley antenna for railroad monitoring. It's also considerably more practical than walking around with 18" of relatively inflexible metal sticking up off your belt, not to mention safer (for you and the radio).
I have used a telescopic antenna at fixed locations, but I've generally found that the improvement isn't consistent enough or impressive enough to warrant using it over the Smiley 5/8 160 model.
